Author Topic: Screw Type for Headlight Bezel  (Read 4476 times)
RobSirg
« on: July 22, 2017, 11:01:44 »
Guys,
I'm trying to confirm the screw type used to fix the chrome headlight bezel to the car body. It's the single screw at the bottom (centre) of the chrome ring. N.B: This is for a RHD 280SL.
Attached is what I found on my car. Do these this look correct?
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
mbzse
Re: Screw Type for Headlight Bezel
« Reply #1 on: July 22, 2017, 11:54:33 »
Quote from: RobSirg
.../... the screw type used to fix the chrome headlight bezel to the car body.../... Do these this look correct?
No, not even close...
These are M4 screws; from factory they were nice chromed special type hardware. Countersunk with cross head. Picture "047" attached. The plastic washer is for retaining the screw onto the headlight door (bezel).
You can use a normal M4 countersunk screw.
As for the M4 screws that hold the alloy frame for the headlights to the pot in the fender, those screws are a special type as well. The head is a smaller diameter than normal pan head M4 screws, in order to clear the glass headlight lens. I have made my own screws by turning down the head diameter. See attached picture. Left to right:  M4 screw as bought, the turned down self made version and an original factory screw.
« Last Edit: August 11, 2017, 11:01:44 by mbzse »
/Hans S
RobSirg
« Reply #2 on: July 22, 2017, 15:39:42 »
Perfect - thanks Hans.
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
« Reply #3 on: July 22, 2017, 20:03:44 »
I think those frame to body screws are stainless steel.
RobSirg
« Reply #4 on: July 23, 2017, 02:20:28 »
Thanks Dan,
Always has me baffled why they have stainless fixings on Chrome trims ( chrome looks better of course). I guess it is because the Chrome can strip after frequent use?
Of course l couldn't find anyone who sells them. MB centre sells them only with the Bezel - which makes it a very expensive screw.
Hopefully someone is enterprising enough to make them up for retail.
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
mbzse
« Reply #5 on: July 23, 2017, 05:32:57 »
Quote from: RobSirg
.../...Of course l couldn't find anyone who sells them.../...
Here is a German vendor, DIN 966 is a useful type for the bezel
http://www.chromschrauben24.de/DIN_966.php?page=gewinde
/Hans S
