Author Topic: Radio interference click  (Read 4244 times)
rgafitanu@gmail.com
« on: July 31, 2017, 15:17:27 »
I have static interference (a click) on my radio when I switch the wipers on or off, when the transmission double solenoid actuates and when I am slowwing to a stop.
I have the Hot Spark ignition so I removed the capacitor that was on the distributor. I am not sure if I have or where to look for an alternator capacitor.
Where should I place capacitors to reduce this crackling?
Thank you,
Radu
Re: Radio interference click
« Reply #1 on: July 31, 2017, 17:45:05 »
Is this on the AM band or is it on the FM band?
rgafitanu@gmail.com
« Reply #2 on: July 31, 2017, 19:42:18 »
FM
WRe
« Reply #3 on: August 01, 2017, 07:04:06 »
you have 3 alternatives:
- noise elemination near the origin: you need noise filter for each origin
- noise elemination near the radio: you need 1 noise filter
- combination of both
First I would try to install a noise filter in front of the radio, e.g.
- https://www.amazon.com/ConPus-Filter-Killer-Engine-Supressor/dp/B01843XVYQ/ref=sr_1_8?s=electronics&ie=UTF8&qid=1501570084&sr=1-8&keywords=noise+filter
- https://www.amazon.com/Sinuslive-13766-Entstörfilter-20A/dp/B003A663P2/ref=sr_1_9?s=electronics&ie=UTF8&qid=1501570913&sr=1-9&keywords=sinuslive.
...WRe
