Author Topic: 051 Dizzy Timing Help!  (Read 8752 times)
vande17941
  • USA, CA, Irvine
Re: 051 Dizzy Timing Help!
« Reply #25 on: August 12, 2017, 01:58:21 »
Checked my temp gauge. It runs hot about 10 degrees until it gets in the upper range. The car runs absolutely fine on temperature until the air conditioner turned on. With the air conditioner turned on and the car idling, even with the fan clutch engaged, the car will just slowly heat up. An infrared gun shows no cool spots in the radiator indicating clogs. What's everyone's experience with what type of temperature increase you see running the air conditioner in idle situations and at highway speeds?
'66 USA (1967 model Year) 230sl, 4-speed Manual, Driven Like a Real Car! Set up with KYB Stiffer Shocks, and Motor Mounts w Urethane Inserts Underneath, 3-point Belts, Headrests Installed 🚗
1986 560sl Cabernet & Palomino (not recommended)
2001 SLK320 Sport AMG Silver & Black
vande17941
  • USA, CA, Irvine
« Reply #26 on: September 12, 2017, 12:37:15 »
After lots of research, reviewing shop manuals, etc, talking with two vintage Mercedes specialists (one who is ridiculously qualified and we'll known), and adjusting and driving three 230SLs it is clear to me that strobosonically setting with a timing gun a 051 distributor at 38 degrees BTDC at 3000rpm on a 230sl will turn the vehicle's motor into a grenade if the motor is driven hard to redline as it was designed. Works great until about 4000rpm or so then pings to the point that motor is going to blow holes in the pistons. This is on all three 230sl's tested.
In California, where we have 91 octane (which is about 3 below what Mercedes specified based on their 98 European octane rating), we must set timing to 28 (twenty eight) degrees BTDC MAXIMUM.  All three vehicles were used to experiment. At 91 octane.....28deg BTDC is it....38 would result in fireworks. There may be a misunderstanding between the various distributors which is is resulting in confusion.
