Author Topic: Original Finish to Hood Lock fixings. Painted or Plated?  (Read 6865 times)
RobSirg
« on: August 05, 2017, 15:16:31 »
Does anyone know the correct finish to the screws / bolts that fix the hood lock at the firewall. If I look at the original 280SL brochure (attached) they appear to be yellow cad plated (see attached). However, I always though this lock was painted in place - including the fixings and I'm fairly sure my original engine bay showed they were painted also. When I look at 49er's (John) original engine bay photo (the colour one) they appear painted there also.
What is the consensus here? Painted or Plated?
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
49er
  • USA, CA, El Dorado Hills
Re: Original Finish to Hood Lock fixings. Painted or Plated?
« Reply #1 on: August 05, 2017, 15:46:10 »
Yep, painted. The screws were painted after assembly with a brush.
John
1969 280SL 003820
4 speed manual, PS. 77K+miles
7K+ miles since awoken from her 20+ yr "nap" in 2010
mbzse
« Reply #2 on: August 05, 2017, 16:35:31 »
I have examined a number of original Pagoda cars, including my own, and the screws are (were left) in gold cad finish.
I have however seen some (original) cars with painted screws in this position. Perhaps there was a variance(?)
« Last Edit: August 05, 2017, 22:27:50 by mbzse »
/Hans S
RobSirg
« Reply #3 on: August 06, 2017, 01:53:19 »
Variances? That's not very Germanic?
I think Painted looks correct and Plating looks better. Would be good to hear from people who also can confirm plating.
Think I will get them plated, that way I can always brush paint them if I don't like it (or I get sick of "experts" telling me it is not original  ;D)
Rob
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
« Reply #4 on: August 06, 2017, 11:51:21 »
The "Holy Grail" from the Motoring Investments website is I believe a 69 280SL shows plated screws as does another 280 Brian restored the engine compartment on.
I am guessing at some point they just stopped painting them.
The Holy Grail:
« Last Edit: August 06, 2017, 12:07:29 by Shvegel »
« Reply #5 on: August 07, 2017, 02:49:36 »
But then again a 1970 with 3K miles.  If you download and zoom in there are remnants of the paint on the screws.
mercakungen
« Reply #6 on: August 07, 2017, 06:56:28 »
A vote for painted screws. On my car the lock has been assembled on the firewall before painting. I´m not sure about the "Holy Grail" but according to some photos it seems that there is some paint left on the screws.
mercakungen
« Reply #7 on: August 09, 2017, 10:25:21 »
What John wrote about a brush made me think.
As you can see from the photos the lock has been assembled before painting. There has also been a round tape between the lock and the body. I think the reason for that tape is that grounding contact thing (interference suppression?). Anyway, to get that tape of they have had to at least loosen the screws which probably has caused scratch or marks on the screws. To touch up those marks they have used a brush. Does this make sense?
BR,
Matti
RobSirg
« Reply #8 on: August 09, 2017, 11:58:55 »
Possibly - BTW the RHD cars do not have that ground contact thing. Wonder if RHD cars were not brushed - and just painted in place.
I was wondering if the they simply used plated screws that were sprayed in place and perhaps the paint came off the plating over time / engine heat?
However, that doesn't explain why a pristine car (as in the 1968 280SL Brochure ) appears to be plated - and not painted from new.
Rob
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
« Reply #9 on: August 09, 2017, 12:47:24 »
Also: the routing of the ignition leads is, I guess, wrong on this picture  ;).
Anyway: I am in the "plated look better" camp.
tel76
« Reply #10 on: August 09, 2017, 19:40:17 »
Rob,
A 1970 RHD does have the grounding thingy, if you want a picture I can send you one.
Eric
mercakungen
« Reply #11 on: August 10, 2017, 05:20:47 »
My car has option code "533"( interference suppression w/o radio set). I believe that the "grounding thing" included in this code.
BR,
Matti
RobSirg
« Reply #12 on: August 10, 2017, 12:53:54 »
Hi Eric.
Might be wrong but I have never seen these copper bars on a RHD car. I do have a braided copper strap under the hood lock which possibly performs the same function? Not sure really.
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
« Reply #13 on: August 10, 2017, 14:18:35 »
The US Federal Communications Comission has regulations about radio interference from cars that go back a long way.  That is why we have resistors in our spark plug wires and why I would assume the aluminum hood would need an additional ground contact.  Many ealy year Corvettes have the spark plug wires in steel channels because the fiberglass bodies will not stop radio interference.
I am guessing that all US spec cars would have had the copper contact and it would be a special order item elsewhere.
As for the painted vs plated screws issue I have a theory that might make sense.  If a car needed the hood catch removed to install the copper ground contact or to adjust it it got unpainted plated screws.  However if the paint was chipped or cracked when reinstalling the screws(Pretty likely) it was touched up with a brush and all 4 screws were painted.
RobSirg
« Reply #14 on: August 10, 2017, 21:46:57 »
that's entirely plausible shvegel. You might have solved it.
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
