Author Topic: Hood tension rod  (Read 3886 times)
Rhinkel
Hood tension rod
« on: August 05, 2017, 22:34:33 »
So I got the car back from the painter a few weeks ago. The hood was weak in holding up but I know the tension rod is good. The end here is poking out. Did they put this in backwards? The curve should be going towards the front of the car correct? I know this is quite a job to fix so I'll take it back of course. Please confirm. Thanks. Rob
WRe
Re: Hood tension rod
« Reply #1 on: August 06, 2017, 06:46:51 »
Rhinkel
« Reply #2 on: August 06, 2017, 13:44:14 »
Thank you for the info but I can't view without signing in.
« Reply #3 on: August 06, 2017, 13:46:25 »
Yes the tension rod goes forward.
WRe
« Reply #4 on: August 07, 2017, 06:02:04 »
here are some photos from the link above.
...WRe
WRe
« Reply #5 on: August 07, 2017, 06:02:40 »
Rhinkel
« Reply #6 on: August 07, 2017, 13:08:04 »
Thank you WRe! That's exactly what I needed!
