Please check out joining the
Emergency Contact List
for help during your travels!
Research & Development
W111 250SE Cylinder head on 230 SL ?
Topic: W111 250SE Cylinder head on 230 SL ? (Read 5599 times)
MercmanBen
August 23, 2017, 15:54:53 »
Hi guys,
I am thinking of fitting a 250 SE cylinder head onto a 230 SL. The cylinder head comes from a W111 Coupe with the engine no. 129 981 22 000040. The head no starts with 129 016 0 as far as I can see.
Would that work?
Thanks a mill,
Benjamin
Full Member
Platinum
USA, CA, Fallbrook
Re: W111 250SE Cylinder head on 230 SL ?
August 23, 2017, 16:02:53 »
Welcome Benjamin - I recall discussions about this recently; suggest you try the search function, but off the top of my head this would not be possible.
Associate Member
Platinum
Canada, ON, Port Lambton
Reply #2 on:
August 23, 2017, 18:02:53 »
But it is very possible. Same head gasket set used on either engine and the part number for a 230SL head set starts with 129 if that's any indication.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
DaveB
Full Member
Gold
Australia, Western Australia, Lathlain
Reply #3 on:
August 23, 2017, 20:29:04 »
Details here:
https://www.sl113.org/forums/index.php?topic=3724.0
DaveB
'65 US 230sl 4-speed, DB190
