Author Topic: w111 Washer Pump Location  (Read 4375 times)
mBdrvr
  • USA, PA, Bethlehem
« on: August 25, 2017, 01:29:47 »
I  know the 250SE washer pump is located somewhere near the brake booster.
Does anyone have a picture or somehow indicate where it lives?
Paul
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
Re: w111 Washer Pump Location
« Reply #1 on: August 25, 2017, 14:47:50 »
On a W111, that is the washer fluid reservoir. The pump is a foot operated bellows and should be on the left side of the foot well. Normally where the high beam switch would be on most cars. It has a switch on it that automatically starts the wipers while the washers are squirting.
rgafitanu@gmail.com
« Reply #2 on: August 25, 2017, 18:46:15 »
I think he is asking where the reservoir is located Wallace. On mine is hanging of the battery top frame although I doubt that is the original location.
mBdrvr
« Reply #3 on: August 26, 2017, 00:25:11 »
My car evidently was retrofitted with an electric washer pump. The old rubber bladder is still there. Thanks for the help.
Paul
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
« Reply #4 on: August 26, 2017, 02:35:22 »
Yes, the reservoir is indeed mounted on the upper battery frame. That is a stock position. The V-8s (3.5L) are of course different. But as far as I know, the washer pump was always a foot pump on the W11 cars.
mBdrvr
« Reply #5 on: September 15, 2017, 18:12:25 »
Yes thanks all. The car was retrofitted with an electric pump. The original works fine. Thanks again,
Paul
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
