with our official
Pagoda SL Group logo
from our official partner.
Clutch pedal
Topic: Clutch pedal (Read 2819 times)
bneville
Clutch pedal
August 25, 2017, 14:18:29 »
The clutch pedal on my 1964 230SL is not returning in a smooth movement after depressing. Right before reaching the top it seems to hangup for a brief moment then releases to the top.
Can it be lubricated.
Thank you,
Brian
Khurram Darugar
Re: Clutch pedal
August 31, 2017, 14:12:36 »
I have the same problem on mine. Although I have a getrag transmission.
I've heard it could be the clutch spring ...... but would be good to hear someone on the forum say the same.
Associate Member
Platinum
Canada, ON, Port Lambton
Re: Clutch pedal
Reply #2 on:
August 31, 2017, 15:06:54 »
I would check the adjustment on the push pin coming from your pedal. It's the same idea as the one for your master cylinder and if you have too much free play your pedal will go over center and act like it's sticking. Adjust the eccentric so that the push pin extends a bit further and this condition should be fixed.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
bneville
Re: Clutch pedal
Reply #3 on:
September 02, 2017, 00:57:31 »
Thank you,
Brian
Atazman
Associate Member
Silver
USA, Ca, Pleasanton
Sticking Clutch pedal
Reply #4 on:
September 02, 2017, 17:05:31 »
I had the sticking clutch pedal problem and finally replaced the master cylinder; end of problem.
Don
67 250 Sl
(#3168) from Italy
5-speed/Posi/AC/Kinder
Associate Member
Platinum
Re: Clutch pedal
Reply #5 on:
September 02, 2017, 19:14:46 »
That can be another cause for a sticky clutch pedal but it will behave in a slightly different manner. A poorly adjusted pedal will have a tendency to not want to return while a sticking master cylinder will left the pedal return but not evenly.
1970 3.5 Coupe
1961 190SL
1981 300SD
2013 GMC Sierra
1965 230SL
Clutch pedal
