Become a
Full Member
Emergency Contact List
General Discussion
what is the weight of an 280sl body
Topic: what is the weight of an 280sl body (Read 3426 times)
CJHenderson
Full Member
Silver
USA, AR, Benton
August 28, 2017, 01:31:45 »
what is the weight of just the 280sl body without doors, hood, trunk? Building a dolly to place the body on to send to the sandblaster and paint shops, and want to make sure that it will be strong enough for transport on a care carrier.
1970 280SL/8 W113 101624 miles.
1950 MG-TD
2021 Harley Davidson CVO Trike
Associate Member
Platinum
USA, OH, Cleveland Heights
Re: what is the weight of an 280sl body
August 28, 2017, 12:53:46 »
It is lighter than you think. 700 lbs max and that is conservative. I built a trailer for mine out of 2" x 2" by 1/4" wall square tube and it was overkill. I used the 4 jack points as mounting points for the chassis. It's been from Minnesota to Detroit to Ohio to Minnesota with no issues. The bigger the casters the easier the rolling. Make sure you leave room for forklift forks between the body and the dolly if they are going to lift it at the sand blasters.
Last Edit: August 28, 2017, 20:46:21 by Shvegel
CJHenderson
Full Member
Silver
USA, AR, Benton
Reply #2 on:
August 29, 2017, 19:18:34 »
That is so cool. Mine I think is going to look like Noah's Ark
1950 MG-TD
Associate Member
Platinum
Reply #3 on:
August 30, 2017, 01:11:36 »
In that case 2 X 6's screwed at the corners (no nails) 4 big swivel casters from Home depot and under the middle run some 2 X 12's where the forks from a forklift can pick it up.
dirkbalter
Full Member
Platinum
USA, CA, Corona
Reply #4 on:
August 30, 2017, 14:32:03 »
Yup, I did something similar. Also 2 x 2 x 1/4 with wheels in the corners, designed to fit my little trailer.
Dirk
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
CJHenderson
Full Member
Silver
USA, AR, Benton
Reply #5 on:
August 31, 2017, 17:18:22 »
That is the way that I went. Need to drill the holes for the jack points mount them and install the cross members to connect both sides. The wheels I got from Harbor Freight with each having a 480 pound weight capability
1950 MG-TD
dirkbalter
Full Member
Platinum
USA, CA, Corona
Reply #6 on:
August 31, 2017, 18:12:33 »
I am sure you know what you are doing but to me the 2 x 4 over the distance shown, look a little weak. Also, you want to make sure that your jack points are sound. My jack points together with my rocker panels would not have been able to support the body. (Your body looks better than mine)
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
CJHenderson
Full Member
Silver
USA, AR, Benton
Reply #7 on:
August 31, 2017, 20:56:54 »
The planks you see are 2x6's and used angle steel to attach the vertical piece to the horizontal planks and then used 2x6 doubles for the wheels support. I think that should hold it for transport. The rocker panels have been removed and it appears that the jacking points is sturdy.
1950 MG-TD
General Discussion
