Author Topic: Brake Booster Eccentric Bolt and Matching Hole  (Read 3522 times)
rbouch8828
  • USA, MA, Framingham
  • 280SL Mfg date AUG 1969
« on: September 01, 2017, 23:48:39 »
On my original Brake Booster, there is an elongated hole on one side of the attach point where the brake side connects, that accepts an eccentric bolt. My replacement booster does not have this special cutout, just normal bolt holes.
Does anyone know what the function of the eccentric bolt was and whether I will have a problem using a common bolt and my new booster?
Roland
RB
hkollan
  • Spain, Castilla-La Mancha
Re: Brake Booster Eccentric Bolt and Matching Hole
« Reply #1 on: September 02, 2017, 07:49:12 »
It's for adjusting the height of the brakepedal.
No problem using a regular bolt except you will not be able to adjust the brakepedal.
Usually only an issue if you have a stick shift.
Expanding the hole to accept the eccentric bolt can also be done of course.
Hans
Hans K, Cuenca, Spain
Mike K
    • Mike Kirkinis
« Reply #2 on: September 02, 2017, 08:11:30 »
Hi Roland,
I undertook this exercise last year, here's my post with pics:
https://www.sl113.org/forums/index.php?topic=25589.msg183237#msg183237
I enlarged the hole to accept the eccentric bolt.
Hope this helps.
Mike
http://michali.zenfolio.com
rbouch8828
« Reply #3 on: September 02, 2017, 12:23:33 »
Thanks for that. Didn't know what it was for and glad to know about how you made the changes.
Thank you both!
Roland
RB
« Reply #4 on: September 02, 2017, 19:17:59 »
Hans
Not sure why brakes would be any different on a standard or an auto. Wouldn't both cars need to stop? :)
rbouch8828
« Reply #5 on: September 02, 2017, 19:45:58 »
I have bought a drill bit and will try to enlarge the hole as you suggested.
Many thanks!
Roland
RB
Mike K
    • Mike Kirkinis
« Reply #6 on: September 02, 2017, 20:47:16 »
I used one of these drill bits when I enlarged the hole and used a slower speed on the drill.
It requires a little patience., the metal on the fork is quite tough.
https://www.amazon.com/Lenox-VB7-7-varibit/dp/B008HQ21EW/ref=sr_1_1?s=industrial&ie=UTF8&qid=1504385016&sr=1-1&refinements=p_4%3ALenox
hkollan
« Reply #7 on: September 03, 2017, 07:09:20 »
I had no clue the eccentric bolt could be used to adjust braking power, happy I learned something new today.    ;)
My understanding is that on a manual car, being able to adjust the brakepedal relative to the clutchpedal position might be slightly more relevant than on an automatic gear car.
Hans
