Author Topic: New Model Water Pump Housing  (Read 2711 times)
rbouch8828
  • USA, MA, Framingham
  • 280SL Mfg date AUG 1969
« on: September 02, 2017, 12:28:21 »
I ordered a replacement water pump housing from Mercedes in Irvine. When I got it I saw that it had two extra mounting holes that my original does not have and that my engine does not have tapped holes to accept mounting bolts for. I called Thomas and he said that the new one he sent is the only one available. So, I've installed it.
I have added a picture of the old and new (New one is at the bottom). Has anyone run into this and if so, is there any issue with using the new one?
Roland
RB
Re: New Model Water Pump Housing
« Reply #1 on: September 02, 2017, 19:24:36 »
Looks like a new design without anything new. How much was that thing, if you don't mind my asking.
rbouch8828
« Reply #2 on: September 02, 2017, 19:43:44 »
$160
RB
« Reply #3 on: September 02, 2017, 21:56:04 »
I get $75.00 for used ones ( when I have them ) so that sounds about right.
JPMOSE
  • USA, DE, Harbeson
« Reply #4 on: September 23, 2017, 12:59:07 »
I just installed a new one as well.  I gather the extra holes are for another “W” model such as a W115.  I was glad I replaced it, as my old one had deep pitting where the pump propeller ride against.  I’m guessing that must be caused by old coolant that got too acidic?   Anyone have another explanation???
Best Regards,
J. P. Mose
1968 250SL
1970 280SE 3.5 Cabriolet
1987 560SL
