Tom,
The Relay is the Programmierbaner Intervall schalter Scheibenwischer Relais, but if you use Google Translate on his site I thinks it says Programmable Interval Switch for Windscreen wiper Relay.
My original relay was starting to play up a bit, so that is why I replaced it, and I was very pleased to find Wolfgang`s site.
I installed it,back in March, and it functions perfectly, I am really pleased with it, and Wolfgang was really helpful.
I had initially a slight problem in that the connector block pins 56 & 56b (going to the Relay) on my car were the wrong way around, after some corresspondance with Wolfgang, we established that there should be a + from the fusebox on 56b, when the ignition is on.This was not a problem with the old Mechanical Relay, but with the solid state a + is required on 56b. I swopped the pins over in the block, and all was good.
Keep well
Paul
