Author Topic: Axle Boot  (Read 2176 times)
steves sl
  • USA, WI, CEDARBURG
Axle Boot
« on: September 04, 2017, 23:08:40 »
I have my 1965 230sl rear axle mounted on a holder that I made which bolts to my engine stand, turned upside down the bracket holds the front x-member. My question, I am planing to replace the axle boot with a one piece boot. After the right  side axle is removed. Can I  slide the new boot around the u-joint? Is there anything else that has to be removed? The original clamps are in good shape. Any help would be appreciated.
S. Schlaefer
Re: Axle Boot
« Reply #1 on: September 05, 2017, 01:06:45 »
Unfortunately, you have to pull the right side axle housing to install the one piece boot.
