Author Topic: Blaupunkt Radio not staying on  (Read 4417 times)
glcg123
« on: September 08, 2017, 03:02:51 »
My Blaupunkt radio has been working fine up until today. I push in the left knob to power it up. The radio will not stay on unless I hold in the knob. Any ideas what might be wrong and how to fix it? If necessary who can I send it to for repair?
George
glcg123
1965 230 SL
250SLFranco
Re: Blaupunkt Radio not staying on
« Reply #1 on: September 09, 2017, 18:54:19 »
Just had my Becker Europa worked on by Becker Autosound, New Jersey.  They are the recommended and I believe only vendor that works specifically on Becker Radio.  They got mine back working, cleaned it thoroughly, and replaced the cracked pin striped faceplate...all for $315.00.  Did a great job, got right on it, and communicated professionally.  I recommend them highly after my experience.
250SL Franco
« Reply #2 on: September 09, 2017, 20:20:13 »
I believe this shop does repair Blaupunkt radios: http://stores.ebay.com/classic-B-B-radios?_trksid=p2047675.l2563
Contact them through eBay.
The usual applies, I don't know the vendor and have never used the service.
glcg123
« Reply #3 on: September 14, 2017, 15:03:12 »
Well, I lucked out today. I decided to remove the knob and found that the radio powered on/off just fine. The problem was that the ring assembly just in behind had loosened which prevented the knob from being pushed in all the way. I tightened it up and reset the knob with the set screws and it works perfectly.
George
1965 230SL
