with our official
Pagoda SL Group logo
from our official partner.
Cold Start Valve seals/gaskets?
Topic: Cold Start Valve seals/gaskets? (Read 3014 times)
vande17941
Full Member
Senior
USA, CA, Irvine
September 09, 2017, 04:40:18 »
Are the gaskets/seals for the 230sl cold start valve still available? If not does anybody have any ideas to fit suitable replacements?
'66 USA (1967 model Year) 230sl, 4-speed Manual, Driven Like a Real Car! Set up with KYB Stiffer Shocks, and Motor Mounts w Urethane Inserts Underneath, 3-point Belts, Headrests Installed 🚗
1986 560sl Cabernet & Palomino (not recommended)
2001 SLK320 Sport AMG Silver & Black
Mike K
Inactive
Silver
South Africa, Gauteng, Johannesburg
Re: Cold Start Valve seals/gaskets?
September 09, 2017, 07:01:04 »
I got mine for my 280SL from Authentic Classics, check with George if it's the same for your 230SL:
http://www.authenticclassics.com/Mercedes-Cold-Start-Solenoid-Hardware-Seal-kit-p/auth-003542.htm
Failing which, when I've not been able to find gaskets I've used Hylomar (from my helicopter flying days) - it's used in the aeronautical industry for sealing aircraft turbines/engines, gearboxes & compressors= non hardening, non- setting, fuel resistant high temp etc.
http://hylomar.com/hylomar-product-range/gasket-jointing-compounds/
Mike
Feb. 1971 Mercedes 280SL Auto LHD (Last of W113 Series)
Aug. 1989 Mercedes R107 300SL RHD (Last of R107 Series)
http://michali.zenfolio.com
http://www.lebombo-safaris.com
Full Member
Platinum
Poland, Mazowieckie, Konstancin-Jeziorna
Reply #2 on:
September 09, 2017, 19:59:21 »
Not sure which ones you mean. If the main one for 230SL, I think A0029975245, it is available in Mercedes and in Niemoeller. The oring - you may want to fit some generic one if no advise comes from the group or search the forum.
