Author Topic: Which clutch pedal ?  (Read 6149 times)
cfm65@me.com
  • Cape Town, South Africa
« on: September 09, 2017, 17:07:37 »
Hi Guys,
I want to start collecting parts for my auto to 5 speed conversion. It seems as if original clutch pedals are no longer available and we have to think out of the box. Has anyone used or modified 108 or perhaps Finny pedals? Which is the closest to the real thing? Any suggestions are much appreciated.
Regards
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
wjsvb ✝︎
  • USA, VA, Virginia Beach
Re: Which clutch pedal ?
« Reply #1 on: September 10, 2017, 02:57:33 »
The 108's used the same pedal cluster as a 113.  This may broaden your search; I hope so!  Jon
jon
67 250SL early
12 Jeep GC (gone but not missed)
69 300SEL 6.3 Euro project (gone but not forgotten)
81 280SL Euro 4spd
cfm65@me.com
« Reply #2 on: September 10, 2017, 05:32:26 »
TKS Jon,
I was under the impression that the Pagoda had smaller, more petit, pedals. But if the clusters are the same, I'm halfway there.
Much appreciated.
Regards
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
GGR
  • USA, DC, Washington
« Reply #3 on: September 10, 2017, 21:21:25 »
When I read the question in the topic my immediate answer was "the one on the left"!
More seriously I used a W108 pedal assy. If I remember well I had to weld a stud. The modification needed will be obvious once you compare your automatic one with the W108 one. Nothing too difficult.
mbzse
« Reply #4 on: September 10, 2017, 21:55:33 »
Quote from: wjsvb
The 108's used the same pedal cluster as a 113...
Yes, that is so. But only until May 1969; after that the 108:s had a different angle on their pedal assembly, does not fit W113 anymore
/Hans S
« Reply #5 on: September 10, 2017, 22:09:23 »
I wrecked a 1968 280SL so I should have a pedal assembly.
cfm65@me.com
« Reply #6 on: September 12, 2017, 03:02:18 »
TKS Doc,
Sent you a PM but I suspect your inbox is full.
Sent you an email as well.
Regards
Chris
cfm65(at)me(dot)com
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
cfm65@me.com
« Reply #7 on: May 18, 2018, 17:11:44 »
Hi Guys,
I managed to find a 110 pedal cluster which fits perfectly, no mods, no nothing.
By the way, it is a RHD 110 pedal cluster which went straight onto the LHD 113, no problem. Same size pedals, same bracket, same mounting points. In fact, exactly the same.
Regards
Chris
Cape Town
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
