Author Topic: Automatic gearbox heating 280 sl  (Read 2897 times)
Allforjags
« on: September 13, 2017, 12:54:44 »
Does anyone knows why 280 sl has hose under the radiator with gearbox fluid. Is this for pre heating.
Thanks for answer
rgafitanu@gmail.com
Re: Automatic gearbox heating 280 sl
« Reply #1 on: September 13, 2017, 13:07:41 »
No, for cooling.
Allforjags
« Reply #2 on: September 13, 2017, 14:28:17 »
But water from radiator doesn't go throw this  hose
rgafitanu@gmail.com
« Reply #3 on: September 13, 2017, 15:07:21 »
Correct. In your radiator there is another small "radiator" only for the transmission fluid. The hydraulic fluid is separate from the coolant. Instead of having a separate radiator for cooling the hydraulic fluid they incorporated it in the coolant radiator. It is a method for cooling both system used to this day.
