Please check out joining the
Emergency Contact List
for help during your travels!
Electrical and Instruments
Timing on 1966 230SL
Topic: Timing on 1966 230SL (Read 2941 times)
Harry
Full Member
Gold
USA, TN, Knoxville
October 04, 2017, 00:38:39 »
The tech manual says the timing on this car is set with vacuum retard connected. But several other manuals I have say to disconnect and tape closed. What is the right method? The dizzy is an -047. Thanks very much!
Last Edit: October 04, 2017, 11:18:26 by Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Associate Member
Platinum
Canada, ON, Port Lambton
Re: Timing on 1966 230SL
October 04, 2017, 14:00:11 »
I set up all of my cars with everything connected because that's the way it works while driving. Set idle timing to about 8 degrees BTDC and check at 3,000 RPM which should be around 38 degrees if everything is working right inside your distributor.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
Harry
Full Member
Gold
USA, TN, Knoxville
Reply #2 on:
October 04, 2017, 14:21:10 »
Thanks very much!
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
