Author Topic: Coil Spring pad id??  (Read 3614 times)
erickmarciano
  • Canada, Quebec, montreal
« on: October 14, 2017, 22:07:03 »
Is there a way to tell what spring pad thickness I have once I remove it?
I will working on the diff and eill replace all rubber . I am happy with the way the car sits
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
cfm65@me.com
  • Cape Town, South Africa
Re: Coil Spring pad id??
« Reply #1 on: October 15, 2017, 07:04:00 »
Hi Erick,
Yes, they have a part number on them IIRC, but you could also measure them. You will find the precedure here somewhere.
Regards
Chris
« Last Edit: October 15, 2017, 11:29:55 by cfm65@me.com »
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
« Reply #2 on: October 15, 2017, 09:49:23 »
I think there may only be one thickness of upper available now but I think you will find the uppers to be quite pliable and fine to reuse.  The lowers which are very thin will most likely be done.
cfm65@me.com
« Reply #3 on: October 15, 2017, 11:37:47 »
Erick,
Attached pics of the different sizes and how to measure them. This is from the SLS web, hinten is rear and vorn is front.
Regards
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
erickmarciano
« Reply #4 on: October 15, 2017, 18:26:46 »
perfect thanks guys
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
erickmarciano
« Reply #5 on: October 17, 2017, 03:28:29 »
I read the part number on mine
Pn 1083250385 ( supose to be 18mm)
But when I measure I get 23mm????
Is the original pn an error?
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
cfm65@me.com
« Reply #6 on: October 17, 2017, 03:57:01 »
Hi Erick,
It is most unlikely to have an incorrect number on a Mercedes part. I am visiting in the UK and will only be able to make sence of this when at home and can look it up in my original parts manual.
In the mean time, hopefully someone might chime in and help us out.
Regards
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
cfm65@me.com
« Reply #7 on: October 17, 2017, 04:21:06 »
Erick,
I managed to confirm that part number 1083250385 is correct for the 18 mm ring.
The image I posted is possibly NOT the correct Mercedes procedure to measure the height.
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
« Reply #8 on: October 17, 2017, 07:03:08 »
I came across this I think when working on my car, but stayed quiet as I was not sure... Try measuring just the seat height, not the full thickness. So try to measure the height in the place where the coil wire ends vs. the base. That is, I think, what I figured in the past.
