Author Topic: Compensator Spring rubber insulator  (Read 2006 times)
CJHenderson
  • USA, AR, Benton
« on: October 17, 2017, 00:04:25 »
Where can I order the Compensator Spring rubber insulators for both the left and right side of the spring?
1950 MG-TD
erickmarciano
  • Canada, Quebec, montreal
Re: Compensator Spring rubber insulator
« Reply #1 on: October 17, 2017, 03:25:01 »
Here is the part number. There used to be 2 sizes , only 21 mm now.
1103290185
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
« Reply #2 on: October 19, 2017, 01:16:23 »
Not sure if you guys are on the same page?  The compensating spring ends are maybe 5 mm thick max.
erickmarciano
« Reply #3 on: October 19, 2017, 03:41:46 »
Yes but they are calculated differently then shock spring pads
21 is overall thickness not thickness of where the coil sits
« Last Edit: October 19, 2017, 21:00:33 by erickmarciano »
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
« Reply #4 on: October 19, 2017, 11:40:30 »
Ahh.  I see.  Nice of them to keep things consistent.
