Author Topic: 230SL Coil Ballast Resistor Bypass Circuit  (Read 4660 times)
mistertj
  • USA, FL, Satellite Beach
« on: October 25, 2017, 13:07:01 »
Does anyone know if the relay in the ballast resistor bypass circuit is energized all the time or just when the starter is energized? I am doing some rewiring to reconnect previously cut wires. Might someone have a schematic of the modification? I'm guessing that the relay is energized as long as the key is on, thus allowing a path 12 volts when the starter is energized.
« Last Edit: October 25, 2017, 16:45:17 by mistertj »
Re: 230SL Coil Ballast Resistor Bypass Circuit
« Reply #1 on: October 25, 2017, 13:24:14 »
Fit a 123 ignition/distributor and do away with the ballast resistors!
mistertj
« Reply #2 on: October 25, 2017, 14:22:11 »
Appreciate the input but would like to stay in original configuration.
Montreal V8
« Reply #3 on: October 25, 2017, 16:58:11 »
  Circuit is energized only via starter circuit. If it was energized all the time the key was on it would always supply 12v to the coil, as the resistor would be bypassed.
  Cheers,   Dale.
« Reply #4 on: October 25, 2017, 17:26:50 »
  >>Appreciate the input but would like to stay in original configuration.
 Orig config did not have ballast bypass on .042 or .043 chassis.
Montreal V8
« Reply #5 on: October 25, 2017, 17:37:35 »
  If you search "starter bypass circuit" you will find a post with a very good diagram - the second diagram, NOT the first.
mistertj
« Reply #6 on: October 25, 2017, 22:51:20 »
I searched but it only brought me to the responses to my inquiry. :(
« Reply #7 on: October 25, 2017, 23:09:31 »
Did you use the search function in the line above starting with "Home" on the left?
If you did you should get 6 hits.
mistertj
« Reply #8 on: October 25, 2017, 23:58:57 »
Yes, I did get 6 hits but did not find any schematics?
« Reply #9 on: October 26, 2017, 00:15:47 »
In hit #2: https://www.sl113.org/forums/index.php?topic=25163
did you not see the schematics in replies #10 and #17?  ???
mistertj
« Reply #10 on: October 26, 2017, 11:53:58 »
I did now. Thank you so much.
