Author Topic: Vinegar vs Nuts, Bolts and Washers  (Read 3416 times)
StevenF
  • USA, NY, Merrick
« on: October 28, 2017, 17:20:18 »
I decided to remove my bumpers so that I can send them out to get re-chromed and take a few dings out of them
The bolts securing the black metal spring were rusty, and so where the inner bolts and nuts holding the bumper guards to the bumper.
I took a can of Coke and poured it into a cup and placed the bolts, nuts and washers in.  I left it overnight and  then next day they were slightly better.  I proceeded to take home the nuts/bolts and washers and placed them in a small bowl of undiluted vinegar and 2-3 tablespoons of kosher salt.  I let them sit overnight and this morning I couldn't believe my eyes! I took a needle nose plier to hold them while I brushed with an old toothbrush and waalaa! Brand new!  You can even see the original name and number on the bolt!
I am sure that the vinegar and salt thing has been done a million times over the years, but sometimes we all need a reminder of how well the everyday household items work better then the fancy chemicals out there.
Best Regards
Steven
1971 280sl
Red Metallic
Bamboo MB Tex
Re: Vinegar vs Nuts, Bolts and Washers
« Reply #1 on: October 29, 2017, 21:13:09 »
The only problem with your approach is the the acid in the vinegar has eaten away the protective plating on the bolts so they will rerust in a hurry.
« Reply #3 on: October 29, 2017, 21:55:21 »
Corrosion inhibitors work fine.  Since I have seen and been the recipient of people looking down on another’s methods I wanted to be clear that my only intent was to warn you.  I didn’t want to see you strip all your stuff and then have it rust in a few days.  Keep in mind that the original plating is Cadmium which is hugely toxic. Google it.  Using acid to clean your parts means there is a chance you are releasing vapors that can be toxic.  All suitable precsutions should be taken.
StevenF
  • USA, NY, Merrick
« Reply #4 on: October 29, 2017, 22:26:21 »
I know you mean well.
1971 280sl
Red Metallic
Bamboo MB Tex
« Reply #5 on: October 31, 2017, 14:17:50 »
Hi Steven,
Long ago and far away, when my bumpers were off being reworked and replated, and my bumper mounts being powder coated, I too had rusty and gnarly looking old bolts and nuts. Since these are essentially benign fasteners in this particular application, strength as it were is not relevant.
Thus, I replaced them all with nearly identical looking stainless steel. Someday, someone might thank me.  ;)
mBdrvr
  • USA, PA, Bethlehem
« Reply #6 on: October 31, 2017, 17:01:39 »
I have used a 50/50 mix of acetone and automatic transmission fluid (ATF).
It works better than the commercial products.
Paul
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
