Author Topic: chain tensioner and manifold gasket  (Read 2940 times)
clunker
  • USA, NJ, Chatham
« on: October 30, 2017, 00:23:38 »
Apologoes for another post, slightly different issue.
I took out the chain tensioner piston and replaced the o-ring etc. When I went to reinstall, I noted it did not sit flush to the head. There is no specific tensioner piston gasket specified, but the adjacent manifold gasket overlaps the chain tensioner piston (see pic). I am guessing the manifold gasket has been install backwards at some point, because pictures of a new manifold gasket show a cutoff at front of engine, which would not then interfere with chain tensioner pivot sitting flush.
My question is to resolve this should I:
1. remove the inlet/outlet manifold (urgh) and correctly install new manifold gasket, etc. - I know thats the 'right' thing to do.
2. use a gasket 180-052-06-80 which is various spec'ed for the W113, and cut off the end to fit round manifold gasket (see pic) - does this gasket really fit in any case on a W113?
3. do surgery on the manifold gasket in situ to remove the part around the tensioner piston stud (this not appear to be a manifold stud) so everything sits square.
I am leaning toward 3., but comments appreciated.
Charles
1969 US 280SL 4-speed Red/Black
DB9 / 981 S / G300 SWB / CB750 / etc
Re: chain tensioner and manifold gasket
« Reply #1 on: October 30, 2017, 05:08:34 »
Yes, your intake manifold gasket is installed wrong. If I were you I would just cut the small portion of the manifold gasket which is entering under the chain tensioner. Adding another gasket under the tensioner is not a good option since it would reduce the travel of the tensioner sprocket.
« Last Edit: November 01, 2017, 07:39:46 by ja17 »
« Reply #2 on: October 30, 2017, 13:51:35 »
Isn't there an O-ring on your chain tensioner? You have to go back a long ways into the 1950's before you would need that gasket because early units didn't have a groove for an O-ring.
clunker
  • USA, NJ, Chatham
« Reply #3 on: October 31, 2017, 00:51:40 »
Thank you for your responses. I did trim the manifold gasket end, and the tensioner now sits flush (see pic).
The tensioner gasket did seem an odd item - I agree it would interfere with the the piston spacing and the function of the O-ring - but it was listed on K&K for W113 so gave it a thought.
I did replace the O-ring, old one was still in good shape but may as well refresh. I did re-prime the tensioner piston by putting some oil in the oil-well in the head, and pumping the tensioner piston.
--Charles
« Last Edit: October 31, 2017, 01:44:48 by clunker »
Charles
