Author Topic: Engine number identification question  (Read 3021 times)
wisnia07
« on: October 30, 2017, 13:09:26 »
Can anyone please help me in identifying my engine type or number?
The car is a '64 W113 230sl and somewhere in the past  the engine had been changed to a 280sl. There are fake numbers stamped on the block, pretending to be a 230sl engine...  I'm doing a complete overhaul of this engine now and I'm wondering how to tell which engine it really is.
Here are the numbers:
Engine nr: 127 981 - 10- xxxx (underneath the left engine mount I found MB part nr: 130 011 01 01)
Head nr: 130 016 1101 with 230 SE stamped on a side (I'm guessing it was 280SE originally and then the 8 became a 3...)
Camshaft: 180 051 08 35 - code number '08'
The bore diameter is 86,5mm and the block has longitudinal coolant channels between the cylinders. All that is saying it's a 130.xxx engine.
After my research, I'm guessing it might be either 130.980 (130E - mounted in sedans) or 130.983 (130 - mounted in 280SL). I assume there are some differences in these two, probably important when ordering major parts for the engine.
Does anyone have an idea how to tell which one it is?
Thanks in advance for any help!
Wojtek
Re: Engine number identification question
« Reply #1 on: October 30, 2017, 13:58:59 »
Looks like you have the late 280SE engine but you should check this out carefully before ordering any parts. The 280 engine and the 280SE/A engine are basically the same but there were many internal modifications that require completely different parts when doing a rebuild. Only real difference between the sedan engine and those used in Coupes or SL's is the gear set for the tach drive along with the associated parts that go with it.
1988 560SEC
wisnia07
« Reply #2 on: October 30, 2017, 18:52:59 »
Thanks for the answer.
Is there any internal detail from which I can tell the difference? I have no chance of tracing the original engine number, so finding a part specific to one of the engines seems to be the only solution.
The question is on which part should I base my supposition regarding the engine type... Any suggestions?
