Author Topic: locating soft top compartment mat  (Read 3763 times)
johnk
  • USA, OH, Avon
« on: October 31, 2017, 01:07:18 »
Anyone know where I can source a new vinyl mat for my soft top compartment? I've been looking and haven't had any luck yet.
John K
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
Re: locating soft top compartment mat
« Reply #2 on: November 02, 2017, 16:09:36 »
thanks Tyler!
Just ordered it.
John
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
BlackJack
« Reply #3 on: June 26, 2018, 13:36:26 »
JohnK, I am in the process of replacing my liner and saw that there are 2 variations offered by Authenticclassics:
1. vinyl covered hardboard
2. vinyl with fibre backing
Not sure which is closest original. Which one did you get and would you mind sharing your experience with the installation?
« Reply #4 on: June 26, 2018, 13:49:31 »
Blackjack, The liner in the link above (fibre backing) has a near identical pebble finish as the original liner. The second offering (hardboard) is a less expensive alternative but is a generic vinyl and has a smooth texture.
BlackJack
« Reply #5 on: June 26, 2018, 14:06:54 »
Tyler S.
My concern with the fibre backing is that due to the extra thickness the soft top might not compress sufficiently in the compartment to close the lid without a problem, but that might be insignificant. Which one do you have and if with fibre backing what kind of adhesive did you use?
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #6 on: June 26, 2018, 14:14:24 »
For reference here is a picture of my original liner.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
« Reply #7 on: June 26, 2018, 16:56:54 »
John,
the pebbled vinyl used on Porsche Targa tops is very similar to the original. Check with upholstery shops in your area they might have it (that's how I got my replacement) or call worlduph.com and ask for a sample. I believe they call it "Levant Grain Topping".
This vinyl could be reasonable match also and it is self-adhesive: https://vvividshop.com/products/2017-vvivid-fine-grain-leather
« Last Edit: June 26, 2018, 17:24:40 by 66andBlue »
