Just from the perspective of an amateur who went through issues related to loss of booster aid:
1. When my brake booster said "enough" and went bad - I could hear the air hissing when I pressed the brake - it was easy to determine that it was the booster that collapsed.
2. After booster replacement I had:
- oring gasket between booster and main cylinder misfitted - I bought a new one fitted it correctly and it was ok for two years
- the hose-check valve from intake manifold to booster went bad, I bought a new one and replaced
These were the simple things. I am sure there may be more.
