Author Topic: Italian Side Mirror or After Market?  (Read 3433 times)
Typpo
  • USA, CA, Los Angeles
« on: November 06, 2017, 00:11:40 »
My 67 250SL is originally an Italian car imported to the U.S. in the early 70’s. It has small round front side markers and the speedo is in KM. It came with these side view mirrors made in England (pic attached). I searched the forum but didn’t find anyone posting or mentioning it but if this has been discussed countless times, my apologies. I am well aware that there were 2 kinds of mirrors for 230SL & 250SL, goose neck, and 280SL. Does anyone know if these were standard for cars exported to Italy, or it was added on by the dealer in Italy, or were they aftermarket mirrors that previous owner attached?
I appreciate your expertise.
_________
Typpo
1967 Mercedes-Benz 250SL
1966 Ford Mustang GT Fastback
2007 BMW X5
neelyrc
  • USA, AL, Birmingham
Re: Italian Side Mirror or After Market?
« Reply #1 on: November 06, 2017, 01:23:34 »
Typpo,
Mirrors, where factory delivered, did not vary by country.  Yours  is likely PO installed.  Have you checked the data card for your car to see what might be indicated as factory delivered?
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
Typpo
« Reply #2 on: November 06, 2017, 01:47:23 »
Thank you for that confirmation. I am a new owner of an early 250SL and haven't gotten to getting the data card yet. But I am now inspired to get correct ones. I love the way the goose neck mirrors look.
_________
Typpo
2007 BMW X5
Tomnistuff
  • Canada, Qc, Levis
« Reply #3 on: November 06, 2017, 02:35:30 »
My 1966 230SL, also Italian, had a slightly different mirror, but black plastic and equally ugly.  It also has a longer bolt spacing than the two traditional M-B models, so I can't even replace it without body work.
Tom Kizer
mbzse
« Reply #4 on: November 06, 2017, 10:32:27 »
Quote from: Typpo
My 67 250SL is originally an Italian car.../... It came with these side view mirrors made in England .../... [were] these standard for cars exported to Italy, or it was added on by the dealer in Italy, or were they aftermarket mirrors that previous owner attached
The matter was discussed long ago; see: https://www.sl113.org/forums/index.php?topic=21123.msg150642#msg150642
My mirrors were made in England as well, they seem very similar or identical to the ones on your SL.
The questions you put forward are relevant; and I would lean towards "added by dealer in Italy" or possibly "mounted by Italian PO" .
The level of workmanship (was: not so good) for the mount excludes factory fit. Besides, the factory would just mount the normal SL mirrors, yes?
On my Italian delivery SL I have replaced these English made mirrors with the standard 280SL type, and mounted them with support plate inside door skin (see pic attached)
« Last Edit: November 07, 2017, 22:27:58 by mbzse »
/Hans S
Typpo
« Reply #5 on: November 06, 2017, 17:59:48 »
Hans:
Thank you for that info. So the Italian cars did have different mirrors prior to being exported. My bolt center distance is 40mm and I found out that the 280SL mirror is the same. When you replaced yours, did you have to do any body or paint work?
_________
Typpo
2007 BMW X5
mbzse
« Reply #6 on: November 06, 2017, 23:41:24 »
Quote from: Typpo
.../...So the Italian cars did have different mirrors prior to being exported.../...
From factory, the W113 Pagoda cars in general were not fitted with external mirrors unless they had one or two external mirrors on the order sheet, from the customer
(note: this customer could be a retailer, placing an order for cars to put on their showroom floor)
Re: Italian market, I do not know if all W113 had "locally mounted" external mirrors.
That is, I do not know if any cars were delivered to the Italian market, from the factory, with the std. M-B mirror type (the type of mirror seen on the green car in my previous posting)
« Last Edit: November 15, 2017, 18:41:25 by mbzse »
/Hans S
zak
  • USA, NJ, Bernardsville
« Reply #7 on: November 07, 2017, 21:11:23 »
Typpo, is your 250 SL an early or late model?
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
1999 E300 Turbodiesel
Typpo
« Reply #8 on: November 08, 2017, 00:30:26 »
It is an early car, 000940. I know the goose neck is the correct one. My choice is later mirror or body and paint work. The existing bolt hole distance is 40mm and positioned too close to the A pillar for the early mirror. Let me know if I'm wrong.
_________
Typpo
2007 BMW X5
