Author Topic: cold start valve  (Read 2170 times)
Taleb
  • USA, NY, SPRINGFIELD GARDENS
cold start valve
« on: November 07, 2017, 17:33:59 »
hello expertise ,
does the cold start valve needs regular maintenance . if so , how to do it ?
Re: cold start valve
« Reply #1 on: November 07, 2017, 18:23:41 »
Not really, although you can check it for leaking as part of your yearly maintenance list. Remove the 7 mm grub screw, turn on your ignition so the fuel pump is running, and check for leaks. Lots on the forum about how to do this.
Taleb
« Reply #2 on: November 07, 2017, 19:18:06 »
Thanks dear
