I know, I saw pictures here, how really worn ball pin adjuster looks like - it has a crown developed, on the picture the crown had something like 1mm. Clear.
I am replacing camshaft and rockers. I thought it would be good to look at the ball pins if I am placing the new rockers there. I am not sure if I the pins are ready to be replaced. I do feel some crown there with a tip of my finger. You cannot really see it as it is fairly smooth shaped. But I feel it. It is not this 1mm high crown someone here showed on th epicture, but it feels it is there.
This is a bit hard to describe, but does this seem to you like an item to replace?
I would probably just screw out the adjusters, not the bases from the head.
