Author Topic: Leaking CSV Solenoid (actual solenoid)  (Read 2773 times)
vande17941
  • USA, CA, Irvine
« on: November 26, 2017, 02:07:05 »
Has anyone here seen a CSV solenoid actually leak gas through its 12v terminal screw hole? I take it that means some internal seals etc in the solenoid itself are toast?
'66 USA (1967 model Year) 230sl, 4-speed Manual, Driven Like a Real Car! Set up with KYB Stiffer Shocks, and Motor Mounts w Urethane Inserts Underneath, 3-point Belts, Headrests Installed 🚗
1986 560sl Cabernet & Palomino (not recommended)
2001 SLK320 Sport AMG Silver & Black
Re: Leaking CSV Solenoid (actual solenoid)
« Reply #1 on: November 26, 2017, 02:24:02 »
There are a few posts I have seen over the years.  It seems to be limited to the earlier large flange valves that were used prior to 1970.  I have seen the solenoid for sale recently for something in the neighborhood of $350.
 http://www.authenticclassics.com/product-p/auth-003022.htm
cfm65@me.com
  • Cape Town, South Africa
« Reply #2 on: November 26, 2017, 03:21:00 »
I had the same problem and it seems to be quite common.  Firstly, you must stop the leaking valve. Try lapping it with toothpaste with very light pressure. Grinding paste is too course.
I managed to find two small O rings from a local bearing shop. Measure the shaft and go half mm smaller, iirc 3mm. Slip them on the end of the solenoid shaft with a little rubber grease between the O rings and the solenoid body. When the solenoid is not powered and the shaft retracted the O rings should 'butt up' nicely to the solenoid.
In our climates, the solenoid should only be powered for a few seconds. I drove around for a few days with the solenoid unpowered in order to confirm the valve had stopped leaking.
Regards
Chris
Cape Town
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
scoot
  • USA, CA, Altadena
« Reply #3 on: November 26, 2017, 15:19:18 »
I've never heard of this before.  I think I still have one for sale on ebay if you want to buy it.  Contact me via PM if you want it.
Scott Allen
'67 250 SL (early)
Altadena, California
« Reply #4 on: November 26, 2017, 19:15:21 »
It does happen. I have solenoids in stock.
« Reply #5 on: November 26, 2017, 21:36:00 »
I had a fuel stop solenoid on the IP leak oil through terminal and it is the same basic design. The O-ring at the base of the CSV solenoid just stops the fuel from leaking at the flange when the CSV activates. If the solenoid leaks at the terminal, it has to be replaced.
