Author Topic: Buzzer always on!  (Read 4114 times)
jpomerenke
Buzzer always on!
« on: December 06, 2017, 14:50:37 »
Hopefully someone can help me.  Just bought a
1968 250SL
When I start the car, an annoying buzzer start buzzing someone behind dash cluster.  Sometimes it will take a second to start buzzing, but seems to kick in when RPMs go up.  (ie: may not go on the second I start the car, but if I rev the engine it will kick in)
I am assuming this is the buzzer for door ajar?
Buzzer will not go on with key in ignition and door open.  Only when I start the car.
I have taken out every relay and connection I can find under dash and even fuse #1.  Still wont go off.  This has me stumped.   electrical short or some sort?
Any ideas?  Or better yet, where is the buzzer coming from and how can I just disconnect it?
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: Buzzer always on!
« Reply #1 on: December 06, 2017, 15:41:23 »
Could this noise becoming from the tach because of a worn gear?
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Atazman
  • USA, Ca, Pleasanton
« Reply #2 on: December 06, 2017, 16:02:48 »
I suspect mrfatboy is correct in diagnosing the tach being the problem.  Suggest disconnecting the tach drive cable beside the engine to see if the noise goes away.
Don
67 250 Sl
(#3168) from Italy
5-speed/Posi/AC/Kinder
« Reply #3 on: December 06, 2017, 17:33:39 »
Same thought came to my mind- the sound of a bad tacho can be similar to an aggressive buzzer noise.
As a quick check - put the tip of your finger on the tacho - can you feel it vibrate a bit? If it does - you know what it is.
If tacho is not vibrating, it can still be the tacho or its cable. The disconnecting of the cable as the next step can help determine that.
