Author Topic: 1965 230SL Run / Idle  (Read 2606 times)
Derm Cain
  • Canada, Newfoundland and Labrador, Colliers
« on: December 06, 2017, 23:35:46 »
I had a person remove the engine from my 1965 230SL for detailing and change out exterior gaskets etc.
The Fuel Pump, cylinder head or rear oil seal were not removed.
The linkage gas and air were reinstalled in the same positions they were in when they were removed.
The car now starts but will not run.
Is there some out there we can chat too or face time to try and resolve the problem.
Does anyone out there have a phone number for someone I can contact to discuss my problem
« Last Edit: December 07, 2017, 13:27:25 by Derm Cain »
Derm Cain
« Reply #1 on: December 09, 2017, 13:00:51 »
Had a guy remove the engine from my car to detail and replace the exterior gaskets.  He did not remove the fuel pump or cylinder head.  When he went to restart the car it starts but will not run or idle.  Maybe a linkage issue.  Do you have a name we can call or face time to see if he can help out.  Certainally no issue in paying the person for his time.
Jordan
  • Canada, ON, Jordan
Re: 1965 230SL Run / Idle
« Reply #2 on: December 09, 2017, 22:17:08 »
Derm, as you are a full member you have access to the "Linkage Tour" which is a sticky in this section.  I would start there and if you are still having problems after that is set up ask more questions here.
Marcus
66 230SL  Euro 4 speed
kampala
  • USA, CA, Beach Cities
Re: Chat Line to discuss 1965 230SL Idling Set Up
« Reply #3 on: December 10, 2017, 13:45:47 »
Since you are already a Full Member, you should religiously follow the Linkage Tour in the Tech Manual.
https://www.sl113.org/wiki/Restricted/Linkage-tour
best of luck
250sl - later - manual
280sl - 1971 - Auto - LSD
Derm Cain
« Reply #4 on: December 10, 2017, 14:29:30 »
Thank you.  Will give it a shot.
