Author Topic: 113 tow hitches  (Read 4896 times)
Desertpagoda
  • USA, AZ, Tucson
113 tow hitches
« on: December 16, 2017, 23:06:02 »
Does anyone know anything about the optional/available ORIS tow hitch for 113s? Does anyone want/need one?
kb
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
Re: 113 tow hitches
« Reply #1 on: December 17, 2017, 15:20:38 »
A few years ago I thought I had a line on one but it turned out to be a home made contraption that didn't look safe at all.
I would like to be able to tow my zodiac to the lake on days when I need some fishing therapy.
I never did find one but still looking.
Ian
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
neelyrc
  • USA, AL, Birmingham
Re: 113 tow hitches
« Reply #2 on: December 17, 2017, 18:55:26 »
As I recall our fellow member Achim (114015 on the forum) had a hitch on his Pagoda at the Euroevent in Merano last year.  Perhaps he can Advise the particulars.
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
mbzse
Re: 113 tow hitches
« Reply #3 on: December 17, 2017, 19:10:12 »
Quote from: Desertpagoda
Yes. It was made by company ORIS (Otto Riehle In Stuttgart), and was offered as a special equipment for W113 Pagoda, via Mercedes dealers.
SA 550.
See pictures. The small mounting brackets were welded onto the chassis of the SL.
Some info about the Oris company here:
http://www.bosal-oris.com/history.html
« Last Edit: December 18, 2017, 05:36:21 by mbzse »
/Hans S
neelyrc
Re: 113 tow hitches
« Reply #4 on: December 18, 2017, 03:50:47 »
....and a pic from Merano......
Ralph
Italy
cfm65@me.com
  • Cape Town, South Africa
Re: 113 tow hitches
« Reply #5 on: December 18, 2017, 04:49:49 »
kb,
I had one on my 230SL in the early 80’s which we towed our Hobie to the beach.
Regards
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
mbzse
Re: 113 tow hitches
« Reply #6 on: December 18, 2017, 05:42:23 »
/Hans S
dirkbalter
  • USA, CA, Corona
Re: 113 tow hitches
« Reply #7 on: December 18, 2017, 21:01:21 »
Mine had a trailer hitch too. I took it off and closed the holes as I was working on the body.
I will post a picture later.
Dirk
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
  • USA
Re: 113 tow hitches
« Reply #8 on: December 18, 2017, 21:10:04 »
Ok, if the W113's had an optional tow hitch, did the package also mention anything about beefing up the rear suspension?  To avoid the tail dragging look.
Re: 113 tow hitches
« Reply #9 on: December 19, 2017, 00:28:01 »
Dear Walter,
No...,
there wasn't such a recommendation by Oris, Westfalia (the other common trailer hitch manufacturer back then) or by Daimler themselves.
The maximum towbar load was/is 50 kilogramms. Not more than some load in the trunk.
(without any trailer hitch knowledge)
dirkbalter
  • USA, CA, Corona
Re: 113 tow hitches
« Reply #10 on: December 19, 2017, 02:26:35 »
For what it's worth,  this is what was installed on mine.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
  • USA
Re: 113 tow hitches
« Reply #11 on: December 19, 2017, 19:40:32 »
Hello Achim,
Thanks for the reply.
Hmm, a factory service literature copy shows a 1200 kg load limit.
Looks similar to the one Dirk shows.
Walter
Re: 113 tow hitches
« Reply #12 on: December 19, 2017, 22:19:27 »
Hello Walter,
Yes, 1200 kg is the maximum total trailer load (towed) - with a trailer containing brakes, less if without brakes.
No, what I was referring to is the maximum vertical ball load for the towing hook, that is 50 kg.
Dirk's and my crossmember for the towbar construction look identical ... only mine has far less rust. ;)
So, he must have had an Oris as well, rather than a Westfalia.
I know that Westfalia had even a detachable tow hook available for the Pagoda. :-) Mine is fixed.
« Last Edit: December 21, 2017, 17:45:17 by 114015 »
