Thank you all for your kind attention!
My engine number is 12010982, late.
First point is that there is a protective hose and a gasket that goes with it. It is not discovering America for most of you. But this was one of the reasons I started looking at it - I saw on the pictures (49er, Motoring Investments) that there is something there I do not have. SLS do not show it.
In the EPC for my car and for my engine I have:
A007 997 7782 - protective hose, engines (983) as of 000178. I see no subsequent part number change for later engines. So this is what doitwright stated.
A130 203 0080 - gasket, engines (983) as of 000178. I see no subsequent part number change for later engines.
I see also that the plastic bands for holding vacuum line to distributor and a hose from coolant reservoir to radiator - are present on early 280 and do not see them on late 280 - so it seems, not sure.
The protective hose is availble 24h form the dealer, the gasket 72h. I will order them and see what I get, they are not so expensive - short or long (I see what you mean on some of the motoring investments pictures, but in Motoring Investments they make lots of mistakes on the details, so unless it is a Holy Grail, I treat them with caution).
Naj,
indeed I found the picture you sent in 114 part of EPC and it is the only place that shows the part and the gasket (tat i swhere I saw the gasket first time). I do not see A 0089978182 on part list for my engine, actually, it looks it is some version of the cooling hose/line from FIP to throttle, not sure.
Matt,
Thank you very much for your kind consideration!
Tczew is a nice town located in the delta of the Vistula river, about 250-300km from Warsaw. It became famous as it was the first home for the Maritime Academy in 1920's when Poland re-gained independence and started building its human resources to man its military and commercial fleet.
Do you have the short or the longer sleeve? As it would be difficult to meet your co-worker, it would require postage sending, repayment etc. - I would not dare to ask for this effort and trouble in case I can just get it here. But in case I cannot get the short one and you have the short one - I will kindly ask you just to sell it and ship it to me - maybe that would be the simplest.
Thakn you all again, I will write what I get.
