Author Topic: Automatic Transmission Linkage  (Read 1855 times)
ejmatushek
« on: December 24, 2017, 02:22:14 »
Anyone know of a source for a replacement linkage rod for my automatic transmission (1966 230 SL)?  The former owner let the transmission mounts and motor mounts go to hell, and the drivetrain sunk down on the transmission support and bent the linkage rod so it can't be adjusted properly.  None of the usual parts suppliers stock a new one.
Re: Automatic Transmission Linkage
« Reply #1 on: December 24, 2017, 11:29:34 »
Is it not available from Mercedes? A1132670059
The system says it is available there for about $30. Truth is that the parts arrangements there are a bit strange as I see two different parts with the same number, so you may want to check what you get.
That is - if I understand correctly what you need.
