Author Topic: cold mixture adjustment for 2 plunger 220SE  (Read 17303 times)
Re: cold mixture adjustment for 2 plunger 220SE
« Reply #25 on: February 16, 2019, 01:53:38 »
Dr. Benz,
You are right. I just called it magic because that is about the extent of my knowledge.
Peter,
I used my thumbnail to clean the injectors believe it or not. I have a stout thumbnail, and kept that way for purposes such as this. You use the nail to pull out the spring loaded pintle in the center and work your nail around the part that seats to the rest of the injector. You need something thin and strong and a fingernail is just about right. It may take several tries if there is some build up. Keep in mind that a really bad injector will never correct itself. It has to do with the spring, pintle condition and the seat.
I have a few NOS injectors and the difference between them and a "cleaned" injectors is staggering. I sure wish they would make a run of these damned things so people with 220SE motors can have one less worry.
« Reply #26 on: February 16, 2019, 06:17:50 »
Dr. Benz,
Peter,
MB hasn't made those injectors in years and it's actually just the tip of it that goes bad. That portion can be unscrewed after the shield is removed. I have lots of NOS 300SE injectors that I wish were 220SE injectors and if MB did re-issue some new ones they would be a fortune like everything else they call '' classic. ''
