Wallace, we are very close
. My comments/clarifications below, next to your text, in italics:
You are correct and that is my poor English - it should be engraved.
OKAs a note:
- All of the tags for the W128 have raised letters "Bosch Germany..." and includes the raised boss on the distributor tag for the engraved 12005309 number.
To ocnfirm: "Bosch Germany Importe d'Alemagn" and the empty field on FIP tag are raised; FIP, not distributor- The numbers in the raised boss (I believe?) is a serial number. The numbers below that is the part number description for the pump. So the serial number should change for each pump.
OK- The distributor and CSV tags are curved when mounted, but probably are flat when manufactured.
The dimensions you gave - they are measured when tag is flat, correct?- Only the distributor has raised numbers/letters for the part number. All others are engraved.
OK- What does Konvex refer to?
It is supposed to be same as raised letters, I hope. Part numbers:
OK FIP - EP/ZEA2KL75R3Z my serial number is 12005309
CSV - EP/EV 1/2 Q
Fuel filter - F1/DZ2/33
Distributor - VJUR 6 BR 49 T
Please take a look at the corrected brief.
