When I bought my 1969 280SL, it had an aftermarket stereo system installed. Fortunately, the PO did not cut the dash, so it was not difficult to R/R the head unit and all of the assorted pieces. I sourced a restored OE Becker Europa (w/iPod adapter), and a Hirschmann automatic antenna. I also replaced the speakers (the holes were already cut) with 4 each Focal speakers, coupled to a small Alpine KTP 445U auxiliary amplifier. The system works great on both FM and the iPod input channels, but on AM I notice a "ticking" sound that varies with the engine RPM. (AM is fine with the engine off.) I have installed resistor spark plugs, a condenser on the LT side of the coil, a Stinger SGN 21 antenna filter, and a Bandit Stereo Noise Filter on each of the hot leads to the Alpine amplifier, and to the Becker head unit. The hood has the spring grounding device installed at the hood latch, the antenna is grounded, and the engine block and the transmission both have ground cables. I have removed and cleaned the connections on all of the ground wires that I can think of. On AM, I still get some ticking noise when the engine is running. I realize that this is 50 YO technology, but I would still like a cleaner AM output. What have I not done?
