Author Topic: Still Need Help Identifying Where Pieces Go  (Read 3642 times)
chrislohrcdm
« on: January 23, 2018, 02:20:04 »
Hi all,
With your help I have put the brackets on that you sent me pictures of.  There are these two things left and then I am done.  Can anyone help?
Thank you!
1969 280 sl automatic
« Last Edit: January 23, 2018, 02:24:33 by chrislohrcdm »
Re: Still Need Help Identifying Where Pieces Go
« Reply #1 on: January 23, 2018, 07:50:38 »
The wire - is it not the three-way solenoid wire for the automatic transmission?
« Reply #2 on: January 26, 2018, 11:56:21 »
#1 looks like the brkt that holds the air pipe to the inlet manifold with a 'P' clip.
The pipe runs from under the manifold round the back of the engine to the little air filter on the inj. pump.
« Last Edit: January 26, 2018, 14:18:53 by Naj »
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #3 on: January 26, 2018, 13:12:32 »
I can't be sure but the top picture looks like part of the bracket that holds the upper steel oil line coming from the oil filter that attaches to the block around tach connection area.
The picture would be missing the clip that wraps around the pipe and bolts on to the bracket.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
450sl
« Reply #4 on: January 26, 2018, 13:12:42 »
wire  startermotor or alternator  to connectionstrip under rightfront engine?
mrfatboy
    • Mrfatboy
« Reply #5 on: January 26, 2018, 13:40:08 »
I just happen to have the part that Naj is talking about on my dining room table along with half my engine.  The wife has not yelled at me yet😆😆😆
It does look closer to your pic because of the off angle bend.
The oil line bracket that I was taking about (also off my car) is a normal right angle bracket.
Signal Red
4 Speed
cfm65@me.com
  • Cape Town, South Africa
« Reply #6 on: January 26, 2018, 18:52:06 »
Chris,
The wiring in the middle photo has three different size ‘connecter’ rings. Those rings go to the electrical connecter under the LH side of the auto box. The other side of that little loom goes to the constant speed solinoid, kick dn switch, etc.
Look at the three different size wire connectors in the photo attached.
Chris
Cape Town
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
chrislohrcdm
« Reply #7 on: February 04, 2018, 19:22:38 »
Thank you so much!
Quick question.  What is the auto box?
Thank you!!!
« Reply #8 on: February 04, 2018, 20:03:51 »
We talk about the three-way solenoid on the automatic transmission. Auto box = automatic gear box.
chrislohrcdm
« Reply #9 on: February 04, 2018, 20:53:41 »
Great!  Thank you!
