Author Topic: 280sl auto transmission removal  (Read 2401 times)
alvan
  • USA, FL, Dade City
« on: January 29, 2018, 19:06:34 »
need directions for auto transmission removal. any papers for that
alvan
Re: 280sl auto transmission removal
« Reply #1 on: January 29, 2018, 20:03:41 »
It is completely laid out in the Tech Manual
https://www.sl113.org/wiki/Automatic/Start#InstallationAdjustment
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
« Reply #2 on: February 02, 2018, 12:11:21 »
If you are removing it to replace a leaking front seal there is a very good chance the leak is where the 'Snout" of the torque converter is rivited to the body of the converter.  Lay the converter on it's back,  fill the area around the snout with water Not inside the converter) and pressureize the converter with compressed air and a rag.  Replaced mine 3 times before I found the leak.  Fix is to have it welded around the enge and around the rivits.
mBdrvr
  • USA, PA, Bethlehem
« Reply #3 on: February 02, 2018, 17:38:23 »
I just removed the transmission from my 250 SE. Toughest part was getting the 46mm nut on the drive shaft to loosen up. I ordered a 46mm wrench from McMaster Carr and use a pipe wrench to hold the drive shaft steady. I assume the 280 SL is the same setup. I used a lift. I'm not sure you could do this without one.
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
« Reply #4 on: February 02, 2018, 17:58:44 »
I very much agree with Shvegel. On my car, what was believed to be a failed gasket was something much more serious.You should absolutely inspect (under a high power magnifier) the weld joints where the internally splined collar is attached to the body of the torque converter. Mine had a very small crack that required replacement of the unit at a cost of about $700.
Larry in CA
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
