Beautiful. That brings back good memories. Believe it or not, mine was the same color as well. If memory serves me right, it’s called Royal Navy Blue.
Anyway,
No, I am using a regular (Miller) mic welder. The spots on the inner fender is the burn thru from the welds of the upper fender support frames. I welded them from the other side by punching (1/4) holes in one of the panels (support frames) and mic welding the panels by closing the holes basically. They do however look a bit like the original spot welds and that’s what I am going for. But I am faking it, lol.
You probably know that, but I would just tag all the panels in place, put the hood in place…., and verify that everything lines up, your gaps are good…. before completely welding a panel.
Good luck
