Author Topic: Worn Manual 4 Speed Shifter  (Read 2572 times)
specracer
  • USA, MA, Duxbury
« on: February 06, 2018, 01:00:22 »
I have looked in the tech manual, and also done a lot of thread searching, and there is a lot of discussion about worn bushings. My shifter is VERY sloppy, and just shifting it, while not moving, feels like a 6 speed. The bushings are actually pretty good. The issue is at the pin that is pressed through holding the splined shaft. The holes are ovaled out, and there is a lot of slop in many directions (see picture i took from tech manual circling the issue)
Is this shaft available new? Common to find them used? Or should I perhaps tack weld the pin?
Thanks in advance
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: Worn Manual 4 Speed Shifter
« Reply #1 on: February 06, 2018, 02:54:50 »
I had a friend spot weld the pin and works great.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
specracer
  • USA, MA, Duxbury
« Reply #2 on: February 06, 2018, 18:30:11 »
Thank you for the reply, I hoped tacking the pin with a weld would be an acceptable solution.
cabrioletturbo
  • Canada, Ontario, Ottawa
« Reply #3 on: February 07, 2018, 02:22:42 »
If the welding does not work out, I believe I have two spares - PM me.
Igor
