All information taken from the technical data manual ("Tabellenbuch"), edition 1969:
breaker point gap: 0.3-0.4 mm
dwell angle: 38 degrees +3, -1 degrees
Bosch distributor part #: IFUR 6 0 231 116 051 (MB part no. 001 158 02 01)
timing: 8 degrees BTDC at idle, and 30 degrees BTDC at 3,000 RPM, both without vacuum advance connected
CO value at idle: 3.5-4.5
Don't know the coil resistance but this may be in the technical articles.
Also check your spark plug wire resistance, end-to-end (should be 1K ohms). These wires are sometimes the culprit when we are confronted with Miss Intermittent. Of course, check the vacuum advance mechanism (springs, binding etc).
Good luck!
