Author Topic: 230SL Injector Pump Thermostat Elongation  (Read 3575 times)
mistertj
  • USA, FL, Satellite Beach
« on: February 08, 2018, 16:06:31 »
Does anyone know how far the Injector pump thermostat center plunger should travel if working properly?
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: 230SL Injector Pump Thermostat Elongation
« Reply #1 on: February 08, 2018, 16:37:14 »
I can't remember if the 230 and 280 thermostats are the same or not. But I remember it's about 23mm for the 280 version.
You can also check out this thread or do own search.
https://www.sl113.org/forums/index.php?topic=20128.0
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
mistertj
« Reply #2 on: February 08, 2018, 17:21:24 »
Mine looks like from cold to boiling water, the plunger extends an extra 3 to 4 mm. Don't know if that's normal?
« Reply #3 on: February 08, 2018, 17:37:14 »
It needs to move at least 1.1 mm or about  .050''  Make sure it's dead before buying a new one because they're about 1K  now!
mistertj
« Reply #4 on: February 08, 2018, 22:27:53 »
Guess mine is ok then with the 3 to 4 mm movement. Does seem kind of a small amount of movement given that it has to move the choke barrel enough to block air flow.
« Reply #5 on: February 08, 2018, 22:57:34 »
mistertj, please make sure you are looking for a good part if you are looking for it. 230 might have had a different one than the later cars. Check the Tech Manual, there is a chapter on it.
But first of all: have you been listening to the air flow at the pump air filter? I suppose your pump has one, as the later ones. You actually hear the air hisss when the car is cold, then this hisssss dies away after a couple of minutes. If this is what is happening, maybe the WRD works ok.
Have you checked the barometric compensator? This is quite a commmon fault and it makes the mixture lean.
