Author Topic: Where do These Grommets Go Exactly?  (Read 2201 times)
« on: February 18, 2018, 00:07:43 »
In the Automatic Transmission parts drawing  we can find these grommets.
Do you know where they go exactly? 2 pieces each are needed for a car.
I can figure out the bigger one goes between the line and a clamp in 2 places, but I am having problems figuring out where the smaller goes and how to install it. The bigge one is cut. The smaller one is not - it is a small pipe. I would have no idea how to slide it on any of the thin lines (it has a dimeter like a fuel injection line or the vacuum transmission line) as they have banjo connectors at the ends. The smaller ones also should go between a line and a clamp (intuitively), but I would not know how to place them without cutting.
Do you just cut it along?
rgafitanu@gmail.com
Re: Where do These Grommets Go Exactly?
« Reply #1 on: February 18, 2018, 06:11:24 »
The smaller one should go on the vacuum line from the intake manifold, there is a bracket holding it down 10-15 cm from the manifold.
Radu
« Reply #2 on: February 18, 2018, 09:29:57 »
Radu, thank you! So you need to cut it as it will not go through the banjo connector on the vacuum line...
rgafitanu@gmail.com
« Reply #3 on: February 18, 2018, 15:49:34 »
Probably, maybe when they made these pipes the first time they mounted the grommet before they crimped the connectors.
« Reply #4 on: February 18, 2018, 19:06:19 »
Ok, thank you.
