If you want to have these made through emachineshop, you will need to download their software and specify the thickness, material and manufacturing process. For best product I would use the EDM process as noted. This results in best finish and edges. You can specify the type steel as well. Would not use SS since that tab will come flat and need to be bent to fit the armature slot when you fit it. Quantity orders are the best way to order these as the price per piece goes way down when you do so. Somewhere I also have the correct ordering info for the brushes. These come from Advance Carbon Products and unlike, many of the counterfeit brushes out there, these are basically the same as the original Bosch brushes as far as material metal/carbon content, size, shape and shunt location and gauge.
