Author Topic: Camshaft and bearings source  (Read 2548 times)
Minerva
  • Ireland, Connaught, Manorhamilton
« on: March 13, 2018, 11:11:38 »
Hi Folks
Just stripping a 250 cylinder head and i have major wear to the back 2 camshaft bearings and of course the camshaft itself. Where is the best source for a replacement camshaft and bearings. Camshaft number is 180 051 8601 (86).
By the way I'm in Ireland so closer to home the better!
Thanks Keith.
450sl
Re: Camshaft and bearings source
« Reply #1 on: March 13, 2018, 15:52:56 »
http://www.kentcams.com/   best give them a call .
« Reply #2 on: March 13, 2018, 16:38:15 »
Check the head for straightness.  I am guessing it is not flat.
Minerva
« Reply #3 on: March 13, 2018, 16:59:44 »
Thanks have tried kentcams, they don't do them.
Yes have to go through the head fully.
Keith.
« Reply #4 on: March 13, 2018, 19:39:36 »
I buy them direct from MB.
« Reply #5 on: March 13, 2018, 20:35:20 »
I have also bought mine from MB recently. It was sth like $700 (no VAT). It was 02.
« Reply #6 on: March 13, 2018, 23:53:20 »
The #86 camshaft was also used on many sedans of the era, in case you want to go on a quest for a good used one. The cam supports are very pricey these days also. Now do you really want to run used rocker arms on the expensive new camshaft??  Costs tend to spiral out of control. Now you have to consider those used ball studs and contact pads ? $$$  SLS is near to you. The MB dealer is an option if you get with a good discount might be a good option.
