Author Topic: Instrument Cluster Connection Plate  (Read 8426 times)
Bill Sgro
  • USA, FL, Bradenton
« on: March 13, 2018, 20:20:17 »
I am looking for an Instrument Cluster Connection Plate for my 1970 280SL.  Part # 000 542 13 78.  My rheostat is not working.
I found one on ebay, but I was hoping someone here had one.  Thanks
1970 300SEL 3.5
Re: Instrument Cluster Connection Plate
« Reply #1 on: March 14, 2018, 00:03:00 »
The rheostat has recently become available again from MB. It's pricey.  Most members do the simple by-pass procedure which will leave the dash lights on full bright when the lights are on. The rheostat can be taken apart and repaired as long as the coil is not broken. To fix epoxy the coil back in it's bed, clean the contacts and coil rubbing surface.
Bill Sgro
« Reply #2 on: March 14, 2018, 02:02:04 »
Joe, I found one on EBAY,NOS still in the box.  I want it to work correctly.  I think I'm going to bite the bullet and replace the whole Connection Plate.   Unless someone has one they would like to part with....  ::)
1970 300SEL 3.5
« Reply #3 on: March 14, 2018, 02:59:33 »
Not sure what you mean by "connection plate"?
« Reply #4 on: March 14, 2018, 04:35:56 »
Bill,
do you mean this part?  :o
https://www.ebay.com/itm/Mercedes-w111-w113-230sl-280sl-250sl-instrument-cluster-connection-plate/401496757954
You better get some assurance that the rheostat still works!
You could buy the complete cluster for about twice the price: https://www.ebay.de/itm/MERCEDES-W111-W113-PAGODE-KOMBIINSTRUMENT/173210780486
doitwright
  • USA, IL, Willowbrook
« Reply #5 on: March 14, 2018, 05:52:08 »
Either eBay option you may still need to repair or replace the rheostat (potentiometer).
Frank Koronkiewicz
Willowbrook, Illinois
Bill Sgro
« Reply #6 on: March 14, 2018, 11:17:42 »
That is the part Alfred. There is a NOS one on ebay also for $650...ouch!
1970 300SEL 3.5
« Reply #7 on: March 14, 2018, 19:27:50 »
Bill, if you are to buy the whole cluster, check the fuel gauge, or at least do not fit it in the car without checking if you have the same (late in your case) type of fuel gauge. Otherwise, in case the cluster comes with older gauge version, you would have to either:
1. Accept the gauge does not work
2. Remove the cluster again to swap the gauges
3. Chnage the sender to the older type, which you do not want to do
« Reply #8 on: March 14, 2018, 19:35:11 »
Bill,
instead of paying $650 (plus taking a chance that the pot has not corroded over time) I'd repair it following the instructions in the technical manual.
My $0.02 (-$650) 😀 !
