Muf,
If you ask for opinions here, you will surly get them! Here are some observations not previously noted:
- Lower trim (mostly) missing on driver's side. The small existing piece by rear wheel is rivited on, but should be clipped on(?) or affixed in a manner that does not show rivit or screw heads.
- Existing trim missing rubber insert.
- Radio is modern replacement.
- Steering wheel is white, but stick shift knob is black. Shouldn't they be the same?
- No rubber floor mats in foot wells.
- Odd (non-original) valve cover breather tube leading back to intake manifold.
I would think it would be easy to find a good Pagoda in Europe, is there a reason you are shopping in the USA?
Also, you say you don't want to spend much to get a car. Even with low labor rates in your country, it will cost a good bit of money to make a poorly maintained car into a reliable driver. It's always smartest to buy the best quality car you can afford. If you want a reliable driver and can't afford it now, then save more money and get it a year or two later. Prices on these cars will go up, but not very quickly.
1966 230SL, Euro, Auto, Leather, both tops
