Author Topic: At 5 speed gearbox  (Read 2475 times)
gordon
  • United Kingdom, England, Burntwood
At 5 speed gearbox
« on: March 26, 2018, 19:08:12 »
I have bought a 1975 car with a ZF 5 speed gearbox which I believe is the same as fitted to a 113. The gear change is almost impossible at times although a new clutch has allegedly been fitted.
Have any members in the UK had a ZF repaired and if so was it expensive?
mbzse
Re: At 5 speed gearbox
« Reply #1 on: March 26, 2018, 19:13:23 »
Quote from: gordon
.../...a ZF 5 speed gearbox which I believe is the same as fitted to a 113.../...
Well, does your gear box look like this?
/Hans S
gordon
« Reply #2 on: March 26, 2018, 20:00:35 »
Hi Hans, I'll check tomorrow. The shift pattern is the dog leg, ie  first gear is bottom left  second is upper right.  Is this the same as fitted to 113?
mbzse
« Reply #3 on: March 26, 2018, 20:06:54 »
Quote from: gordon
.../...The shift pattern is the dog leg, ie  first gear is bottom left  second is upper right.  Is this the same as fitted to 113?
/Hans S
gordon
« Reply #4 on: March 27, 2018, 17:49:43 »
Ok, so it seems that my at box is different to the Pagoda box. Are parts still available for repairs?
swood1
« Reply #5 on: March 29, 2018, 08:51:46 »
Gordon,
Are you sure you have the correct 5 speed gearbox on the car?
Steve
